Продам отличный дорожник!Все расходники поменяны Новый АКБ новый задний балон передний норма!Только при осмотре возможен торг!!!Причина продажи,хочу чепер! Т.89053261414 цена 155 000р
Год 1989,пробег 25800,полносил 145л/с 1200сс,наличие буста,обгонка в норме при сробатование выстреливает ракетой!
V-Boost
V-Boost is a system that opens butterfly valves in the intake manifold between the 1st and 2nd and between the 3rd and 4th cylinders starting from 5,750 rpm. The valves are opened gradually to match the rising rotational speed signal provided by the ignition system. The valves are at the full open position at 8,000 rpm. There is a small black box that reads the rotational speed and sends a computed signal to a servo motor. The servo pulls a wire to open the butterfly valves. The V-Boost System adds 10 percent to the top power rating of the base engine.[8]
